Compteur 309
Re: Compteur 309
Messagepar alargeau » 07 Avr 2011, 19:09
Did you have a look in here?
Avatar de l’utilisateur
Modèle(s) 309: SL - GTI
Re: Compteur 309
Messagepar missa91 » 07 Avr 2011, 19:19
alargeau a écrit:Did you have a look in here?
Yes, yes, I did, but the TU3 and G1A are quite different and there it is described using a splitter of sorts. In my case there is no space to fit something like this. But I'm rather looking at a solution with only one sensor. Do you know of one that does this? and do you know if there are lines already present in the connections to the Jaeger dashboards?
309 GTI 8V 5-Door Phase 2
missa91
Modèle(s) 309: GR
Re: Compteur 309
Messagepar alargeau » 07 Avr 2011, 19:25
It depends on what you want. If you want to change your Jeager clocks because you prefer the Veglia ones, then you can simply find the Veglia model with 4 clocks. It's plug and play and no fiddle is necessary. Then, if you really want the 6 clocks some fiddle will be necessary. I honestly don't know if that's possible to get one sensor that'll do everything. In the topic I mentioned earlier, Thomas didn't find a three-socket connector so we found another way to do the trick.
Re: Compteur 309
Messagepar missa91 » 07 Avr 2011, 19:35
I already have a veglia fitted, and yes it was plug and play. But I want to keep and eye on oil pressure. And fitting an external gauge is for me without taste. So i wanted to fit a GTI clock and connect the sensors. Do you perhaps know the connector dimensions on the G1A? The diameter and the type of thread? I mean something like M16x15x1.5....
missa91
Modèle(s) 309: GR
Re: Compteur 309
Messagepar alargeau » 07 Avr 2011, 19:41
I think it's M12x1,5
Re: Compteur 309
Messagepar missa91 » 07 Avr 2011, 20:10
In the GTI, are the pressure sender unit and pressure switch the same part?? Does one sensor do both tasks? and where does the oil temperature gauge go? does someone have a picture?
I can't seem to find anything but the pressure switch
missa91
Modèle(s) 309: GR
Précédente
Qui est en ligne
Designed by A. L.
Les forums de Peugeot 309.
