wiring on the digital clock's connector
If you see wires, but still have your hands clean, that's the right forum.
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 26 août 2011, 00:22
Does anyone know what should be the plus and the minus on the 3 wires on the connector for the digital clock?
Re: wiring on the digital clock's connector
Message par thefunkyboy » 26 août 2011, 08:18
I have absolutely no idea for my part.
Did you try with a multimeter? It is the best solution I guess
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 26 août 2011, 13:32
I did and that's what i don't get, it seams two of them are plus and the other is minus. It's logical up until now. But I thought one of them should be connected to the light, and when I turn the light on there should be current. Right now there is always power to both pluses
The problem is that there is no back light on the clock. The clock works well, but no light. From what I remember there should be a light, right? (I haven't had my clock connected for years and I am not sure)
Message par Attila97 » 26 août 2011, 14:48
You have a 4 way connector.
Pin 1:
number: B7M
color: grey
function: +12V permanent
Pin 2:
number: M7M
color: green/yellow
function: minus
Pin 3:
number: A3M
color: white
function: +12V after contact
Pin 4:
number: D13M
color: green
function: +12V for light
Message par thefunkyboy » 26 août 2011, 17:43
Ah! There is two models i guess, mine doesn't have a back light. Maybe it is possible to mix them?
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 27 août 2011, 11:09
problem solved, it does have a backlight, but i didn't know that it comes on on the second position of the ignition key.
Message par thefunkyboy » 27 août 2011, 11:23
Great!
That was a pleasure ti help you restoring your GT :)
