What about the 309 GT ?alargeau a écrit :Hi,
Quite easy to figure out:
- 405 MI16 : 6J15 CH4.29
- 309 GTI : 6J15 CH4.19
- amilo123
- Modèle(s) 309 : GT
It is the same for all the 309s
- amilo123
I hear a squishing sound when I press the brake peddle, when the engine is on. I know it is normal with the engine off, but with it on I am not sure.
I did the brake cylinder test described in heynes and it went well.
Could there be air in the brake system? I never replaced the brake fluid, I am not sure if it is the original one, but it has more than 10 years for sure.
Otherwise the brake works well.
10 years!!??
Dude, normally you should change it after 2 years
- amilo123
I know, I asked many mechanics but they all said "if it works don't change it" (typical romanian
I will change it.
I will change it.
amilo123 a écrit :I know, I asked many mechanics but they all said "if it works don't change it" (typical romanian) )
I will change it.
Be carefull while draining: the drain screws may have suffered because of the liquid corrosion
I think the brake fluid will be black with a touch of orange due to rust...
- amilo123
Hello,
Recently I get a lot of black smoke when I accelerate. I changed the fuel filter, spark plugs and I cleaned the carb with cleaning spray (It didn't seem that dirty). The engine is running very smooth, the idle is steady. Fuel consumption is 15-16 l/100km (only city driving, under 20km at a time). It is cold here in this period, around -5, -10 C.
I tuned the carburettor in the fall, there was almost no smoke, the plugs looked good then, now they are black.
I would change the air filter as well, but it is from K&N and it says 25k miles between cleaning, and mine has 15k km.
The smoke appears only when I accelerate and when I start the car (the snow behind the car turns black as well). But if I accelerate it hard for a couple of times, the smoke begins to disappear, almost entirely.
The thing is fuel consumption is really high...
I think so too, did you try to measure the lambda ratio?
- amilo123
How could I do that?thefunkyboy a écrit :I think so too, did you try to measure the lambda ratio?
You should have to go to a car mechanic to check it with an appropriate aparatus. Your gaz consumption is so important, moreover with a good carburator.
- amilo123
i know, with a CO meter right? the thing is that everyone has injection nowadays, and I don't think anyone would do this.thefunkyboy a écrit :You should have to go to a car mechanic to check it with an appropriate aparatus. Your gaz consumption is so important, moreover with a good carburator.
I thought I got the fuel ratio right, because the idle is steady, and at 800rpm...
- amilo123
OK, I will try to find someone with a CO meter, but shouldn't I wait until the weather becomes warmer, 10 C at least? Couldn't it be just a fuel vaporization problem, because of the cold?
I don't think it is so important with a benzin car. The cold has more impact on a diesel car, for sure.
Yes, you need a CO meter. In France, it is also hard to find but to succeed, you need to find a small enterprise
