- amilo123
- Modèle(s) 309 : GT
total quatz energy synthetic 10w-40, from march
- missa91
- Modèle(s) 309 : GR
hm.... are you sure that synthetic oil is recommended for these older engines? I remember you saying that there is blue smoke coming from the exhaust, isn't that right?
309 GTI 8V 5-Door Phase 2
I put 10w40, half synthetic, in my 309
- amilo123
missa91 a écrit :hm.... are you sure that synthetic oil is recommended for these older engines? I remember you saying that there is blue smoke coming from the exhaust, isn't that right?
no, not from the exhaust, from the cap where you put oil, when the engine is over 3000rpm, and at idle there is a pulsating sensation
- missa91
I use 15w-40 mineral, as prescribed for the simca.
- amilo123
I am not sure which is it, on the box it says synthetic, but on their site is says semi-syntheticthefunkyboy a écrit :I put 10w40, half synthetic, in my 309
- amilo123
10w-40 is also recomended for the 309, always used it.missa91 a écrit :I use 15w-40 mineral, as prescribed for the simca.
And 10w vs 15w si only their peformance when cold, w is for winter.
As for the smoke from the cap, I never really understood why, some say that it is normal. Do your engines do the same?
Modifié en dernier par amilo123 le 24 mai 2011, 23:56, modifié 1 fois.
- missa91
yes, yes, but my engine is a lot different than the one you have amilo123. As I remember you haven't got a filler cap on the cylinder head. but on a hose. Isn't that so?
I always put 10w40, on both my cars.
- amilo123
the fuel filter, yes.missa91 a écrit :yes, yes, but my engine is a lot different than the one you have amilo123. As I remember you haven't got a filler cap on the cylinder head. but on a hose. Isn't that so?
I don't think it is a cylinder ring problem, the valve theory on c3 seams more likely. Because between oil changes I almost never need to put any oil in.
First I think your carb is not tuned correctly because you have white ends. Then I agree with the cylinder problem. You may have a leak somewhere and that's why the spark plugs have oil and your compression ratio is quite bad with C3.
- missa91
so, the as do the mechanics say: until we take her apart, there is nothing to know
- amilo123
I think so too with the carb, I will try to tune it myself when the book arrives.alargeau a écrit :First I think your carb is not tuned correctly because you have white ends. Then I agree with the cylinder problem. You may have a leak somewhere and that's why the spark plugs have oil and your compression ratio is quite bad with C3.
Tomorrow I will put some oil in c3 to see if it improves compression.
Isn't white ends an indication of too little fuel in the air fuel ratio?
Yeah, it's a good way to know. If the compression improves (and I'm quite sure it will), you're good to open the engine!!
Yes but if it remains working like that, just wait. It is quite expensive to repair an engine. But anyway, there is the solution to buy another one and to repair it with time, then mounting it on your car.
