Page 17 sur 19
Re: Restoring the power of a 1986 110bhp XU92C engine
Posté : 17 févr. 2012, 15:59
par amilo123
thefunkyboy a écrit :I don't think it is so important with a benzin car. The cold has more impact on a diesel car, for sure.
Yes, you need a CO meter. In France, it is also hard to find but to succeed, you need to find a small enterprise
Yes but I am not sure that the exhaust system is without leaks.
Could there be another cause? I want first to resolve every possible problem and then go to a CO meter.
And does anyone know what is the correct CO value? I found somewhere 1.5% +- 0.5
Posté : 17 févr. 2012, 22:41
You should ask to "attila97", he also owns a 309 GT
Posté : 18 févr. 2012, 00:23
par amilo123
thefunkyboy a écrit :You should ask to "attila97", he also owns a 309 GT
I think there is also a problem with "false air", from the servo-brake, I think it looses vacuum, I will check tomorrow.
Posté : 18 févr. 2012, 13:37
I've the same value for the CO. 1,5% +-0,5.
On my GT, the value is 1% after a correct setting of the engine.
And I've also a problem with the servo-brake, as you!
Posté : 18 févr. 2012, 14:50
par amilo123
Attila97 a écrit :I've the same value for the CO. 1,5% +-0,5.
I sent you an email, please have a look. Thanks!
Posté : 18 févr. 2012, 21:25
par amilo123
I have an idea: How about I install an O2 sensor, and a digital volt meter in the car like this one
http://goo.gl/yQ1RP" onclick="window.open(this.href);return false; The whole system would set me back 35 euro, and I could tune the carburetor anywhere anytime. What do you think?
clutch problem
Posté : 13 mai 2012, 19:37
par amilo123
Yesterday I noticed a weird sound coming from the clutch. I opened the hood and found that the clutch fork was oscillating, proportional to engine speed. This oscillation, along with the sound (a hising sound together with clunching) lasts for 30 seconds then I hear a louder clank and everything returns to normal.
Then if I press the pedal I hear another small clank, and when I release it the sound and vibrations reappear again for 30 seconds.
This happens whether I drive or at idle. When the peddle is pressed, even slightly everything is normal. When I put my foot under the peddle and raise it a bit the sound disappears, but the oscillation of the fork remains.
There are no other symptoms. Gears are changed smoothly, no vibrations when I drive off.
The clutch was replaced (apart from the flywheel, but that was ok) last summer. It is a LUK. It has less then 10 000 km.
Posté : 17 mai 2012, 01:35
par amilo123
ok, now it sometimes squeaks when I fully press the peddle. How can this be on a new clutch and bearing?
Posté : 17 mai 2012, 08:40
Could you make a video to capture sound at least?
Posté : 20 mai 2012, 02:09
par amilo123
It seems that the pressure plate is the cause of the sound.
I put some wd-40 inside the clutch, trying to get it on the bearing. The sound went away, and the vibrations last much less, a couple of seconds only.
I bought this camera
http://goo.gl/dG1un" onclick="window.open(this.href);return false;
It fits inside the clutch so I can see exactly what's wrong
. Plus I can get the WD-40 exactly where it needs to go.
BTW: My spark plugs are finally reddish
fuel economy is almost 11 in the city. Hope it stays this way.
Posté : 20 mai 2012, 09:49
Nice camera. What is a "pressure plate"? Could you put a picture to show what it is?
Posté : 20 mai 2012, 10:06
Pressure plate = plateau de pression :
Posté : 20 mai 2012, 10:18
Ah ok! But it has been changed with the whole clutch, isn't it?
Posté : 20 mai 2012, 11:09
par amilo123
thefunkyboy a écrit :Ah ok! But it has been changed with the whole clutch, isn't it?
It has, that is the weird part....
Posté : 20 mai 2012, 18:49
What is the brand? LUK? Valeo? something else?
