rear tapistry
- Al_Bundy
- Membre GL
- Modèle(s) 309 : 309 xld
rear tapistry
Hi,just 1 quicky:
how can i remove the rear tapisery,you know that small,right under the rear glass,U-shaped.cuz its in bad shape.
i can see it has 2 plastic things-(dont know how to label it).
thanks.
(i told you ill have question)
thanks.
score 4 touchdowns in just 1 game!
Re: rear tapistry
Yes, it has two plastic clips. You just need to remove them I guess.
Re: rear tapistry
Do you have any picture?
- Al_Bundy
- Membre GL
Re: rear tapistry
yes,2 plastic clips,i thought maybe it has something more,i will try to take it down today,later ill post some pics of the legend
Re: rear tapistry
I think it has more than two clips... Try to touch from the inside of the boot.
- amilo123
- Membre SR
- Modèle(s) 309 : GT
Re: rear tapistry
You need to remove those 5 ornaments, from the vent holes. Apart from the plastic clips, they hold it in place. But be careful because the plastic is easy to break.
- Al_Bundy
- Membre GL
Re: rear tapistry
this is the rear tapistry,the one holding to the back door,yes,there were 2 round plastic clips and also those 5,which began to snap fast so i gave up,simply,too easy they snap.
- DSC00275.JPG (40.32 Kio) Vu 31483 fois
Re: rear tapistry
These vents holding the carpet are just shxx!! You can only remove them once because they break in your hands.
- amilo123
- Membre SR
Re: rear tapistry
i know, they broke when I got mine off. No they don't hold the carpet anymore, I had to glue it in place
- Al_Bundy
- Membre GL
Re: rear tapistry
yes,i was really carefull and still they,broke imidiatly.
but ok,they spent entire time directly under the glass on the sun,its plastic,it was bound to happend.
