You are talking about lights that don't work but are we only talking about the ventilation bulbs? If yes, there are only two bulbs and both are powered with the same cable. Actually, there is only one cable that powers the circuit board and it's a 5-pin cable. If you remove the ventilation plastic, you'll be able to see the connections and the first two power the bulbs, no matter the circuit board you have (B or C). I took a picture of my previous circuit board to show you. As you can see from the picture, I circled the connectors that power the bulbs:
Make sure the 5-pin connector is correctly inserted from the back. If it is, and if you have a multimeter, turn the headlights on and control that you have power at both connectors. In order to have access to the back of the circuit board, you don't need to unscrew it, just remove the plastic cover which is between the ventilation plastic and the stereo and which can't be seen at first. It is situated here:
PS: I posted a message in our French forum so we can think with more than two brains. The more we are, the faster your problem will be solved.
