5w40 or 10w40 oil? Benzine excess consumption?
- amilo123
- Modèle(s) 309 : GT
Hi, I have a 1986 Peugeot 309 GT with 176000km and the 82kW XU92C engine.
Currently I have a semi-synthetic elf competition ST 10w40 oil which I want to change. I know it is a poor quality oil and I want a higher quality one. Someone told me that any engine would benefit from a change from 10w to 5w, is this true of this engine?
I was looking at the Total quartz 9000 (5w40) or the quartz 7000 (10w40)...anything better than these?
thank you!
thank you!
Re: 5w40 or 10w40 oil?
Hello,
First of all, you need to introduce yourself in the appropriate section.
Then, Peugeot recommends 10w40 oils. I don't think there's any benefit in putting a 5W40 oil in those engines. Plus when they're old, they tend to leak so a more viscous oil is not recommended. I buy 10W40 oils for both of my 309s (GTI and non-GTI) and the Total Quartz 7000 is a very good oil. There's the Castrol GTX too.
- Thomas 309
- Modèle(s) 309 : Graffic
Hi,
I am the same opinion as Aurélien. The motors are designed for 10W40 and work with it perfectly. I always use 10W40 oil that is filled at Peugeot every year (original Peugeot Oil from my Peugeot-dealer). Only poorer quality, I would not recommend it. However, But I've also thought about to try 5W40 or 5W30 oil...
Regards, Thomas (is already looking forward to get back its 309 Graffic from hibernation in two weeks-and than DRIVING)
My vehicles:
PEUGEOT 309 Graffic 1992
Wartburg 353S 1987
Nissan Leaf e+ 62 kWh 2021
SIMSON Schwalbe KR51/1
SIMSON SR50 B4
I already tried 5W40 (on a XU5-2C) and I will advise against it ...
The engine uses too much oil, probably because it is more fluid.
On a XU engine 8 valves, the best viscosity is 10W40. On a TU engine, I prefer the 15W40 (less noise because of the tippers)
- amilo123
thank you very much for the responses! I will put the quartz 7000 oil today
as long as I am here, may I ask, how hard/expensive is it to put air conditioning in this model?
Can you open another topic for this question?
The most appropriated person to answer to this question is Baptiste (SRDTurbo)
- amilo123
In the end I went with the total quartz 7000 energy (10w40), I put it in today.
I hope this solves the problem with the oil getting very hot, around 115 degrees
I don't think the oil is the problem. I have used the Elf Competition ST in the past and even though it's not the best oil on the market, it's definitely not the worst and is way above average.
The Shell hellix plus is a good one,10w40
- amilo123
well what could the problem be then? should I be worried?
It depends. Does your sensor work properly?
My GT used to have a high oil temperature. I never found the origine
- amilo123
I'm not sure. Last year, in the summer it rarely reached 100. And now even in this rather cold weather, when I drive more it reaches 110-115, the water stays at 70-80.thefunkyboy a écrit :It depends. Does your sensor work properly?
Almost all the coolant is new and the water pump as well, also I removed the air from the cooling system, but only through one of the holes, the one behind the air filter. I know from my mechanic that there is another one just above the engine, but he says the cap is stuck and he advised against forcing it...
When it was newer, 5-7 years ago, the oil stayed at exactly 90
Is your Igniter well calibrated? (too much advance can create that oil temperature phenomena)
- amilo123
Well, I don't know about that... And I don't think my mechanic knows how to calibrate it.thefunkyboy a écrit :Is your Igniter well calibrated? (too much advance can create that oil temperature phenomena)
I saw that the idle speed isn't smooth at all... The carburetor was calibrated last summer, but I think I need to go again to that guy...
The mileage I get isn't either as it says in the book... It consumes 13.5 l/100km, last I checked, but this could be because of the cold weather to. In december I got 16 l/100km lol
