rear wiper motor
amilo123
Modèle(s) 309 : GT
rear wiper motor
Message par amilo123 » 08 sept. 2011, 16:28
My rear wiper motor hasn't ever worked. I am not even sure how does it work.
I recently bought another motor from someone, and I connected it to the plug but nothing happened. And I just wanted to be sure that there is no problem on my end before I accuse him of anything.
On the plug there are 3 wires and I am not sure why. One is ground, one has 12V when the key is turned and the other has 12V when I press the button. Is this correct?
BTW: the pump also was broke but I changed it and now it works.
Re: rear wiper motor
Message par alargeau » 08 sept. 2011, 17:05
Here you go (see page 12 then): viewtopic.php?f=103&t=1888" onclick="window.open(this.href);return false;
beni
Modèle(s) 309 : Grrrrrrrrr
Message par beni » 09 sept. 2011, 07:05
amilo123 a écrit :On the plug there are 3 wires and I am not sure why. One is ground, one has 12V when the key is turned and the other has 12V when I press the button. Is this correct?
yes, that's it.
your car is a mark 1 or mark 2 ?
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 09 sept. 2011, 22:21
mark 1
but i still don't understand the need for the 12V on contact if the mark 1's rear wiper doesn't return to it's right position by itself (or does it?)
beni
Message par beni » 09 sept. 2011, 22:44
I think it does, otherwise the 12v after contact is useless.
When you press the button, you have the 12v on the connector?
Also check your ground .... I'm not sure but I heard that on mark 1 the circuit was made by the trunk cylinder, you can also look out ....
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 09 sept. 2011, 23:02
beni a écrit :I think it does, otherwise the 12v after contact is useless.
Yes I do have 12V on the connector. I didn't try the motor with the trunk closed yet though, I will do it tomorrow, even though I measured the voltage with it's own ground and with the trunk opened...
beni
Message par beni » 09 sept. 2011, 23:08
try with the trunk closed ... otherwise, I feel that your engine is dead ...
You can also test your engine by connecting directly to a 12v
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 10 sept. 2011, 18:46
beni a écrit :try with the trunk closed ... otherwise, I feel that your engine is dead ...
the motor works, but it doesn't return to it's position, still haven't found the use for the 12V on contact
beni
Message par beni » 11 sept. 2011, 06:33
ok! I had read too fast ... on your engine ensures that the wire that brings the 12v after contact is not melted or short circuit to ground ... it happened to me once, the engine had to force to get back into position and the wire had melted on the engine ...
