[moustik76133] un peu de news
Re: [moustik76133] gti vendue,ne part plus :-)
J'ai des murs blancs dans ma chambre avec des bandes PTS comme frise, suffit de bien présenter la chose (c'est pas mentir, juste faire des essais et faire semblant de trouver cette combinaison).
Pour avoir vu, ça rend bien
On veut pas savoir ce que vous faîtes dans sa chambre.
Meunon, mais puisque c'est comme ça même si tu me le demande gentiment je ne te peindrais pas une frise à l'éponge sur de la tapisserie!
nouvelle page ,photos ????
photos photosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosphotosv
juste pour toi alors :
moteur propre,allumeur et embrayage remontés:
derrière du moteur propre ^^( me reste le joint de boitier d'eau a commander ....mais avec mes tops magasinier j'ai peur ...):
coté distrib :
dans la bv,joint de guide de butée a changer ,mais la fourchette bloque ....comment faire ????????????
réponse : on enlève la goupille de maintient de la fourchette/levier d'embrayage :
du coup le levier est libre:
et voila , la fourchette pivote assez pour libérer le guide de butée et son joint :
du coup "pouf" on l'enlève et .....on attend le neuf que ces *********de ******* de******** de********** de magasiniers de chez peugeot ne sont pas capables de référencer et de m'envoyer ....
désolé,les photos sont vraiment très moyenne...
coté distrib :
J'avais pas réussi à l'enlever cette goupille moi !!! j'ai tout essayé...écrou contre écrou, toutes les techniques vaches et méchantes...ca a fini par faire une connerie...j'ai changé de BV !
Comment t'y es tu pris pour la défaire alors?
règles a suivre jeune homme :
- pour cette goupille extraire,de la patience il te faudra
- "de wd40" t'armer tu devras
- plusieurs jours tu attendras
- comme par magie sans forcer alors, elle sortira
au fait, je pense avoir la douille du guide en stock ! comme je ne l'ai jamais montée et je l'avais achetée chez pigeot !
ca t'intéresse ?
ca t'intéresse ?
Oki maitre MousYoda
merci, mais trop tard elle est sur la route ,ce week normalement la bv retrouve son emplacementjojoe31 a écrit :au fait, je pense avoir la douille du guide en stock ! comme je ne l'ai jamais montée et je l'avais achetée chez pigeot !
ca t'intéresse ?
si j'ai le temps aussi ,je peint l'autre face de mes ressorts d'amortisseur et semaine prochaine je remonte mes jambes de force
Oki !
(j'allais te l'offrir, comme taxe de séjour en Normandie !
Sinon, c'est mieux de remonter la boite + moteur dans la caisse ? que de remonter la boite aprés?
je me concentre sur le remontage et promis,nous irons faire un tour de 309 dans ma campagne
pour le remontage,je vais tout remettre en même temps,sauf si je vois au dernier moment que c'est trop risqué pour la peinture ,je ferai en 2 coups : le moteur seul,puis la bv
