is this the carburator's electrovalve? how does it work?
If your hands are dirty, that's the forum you should post in.
Re: is this the carburator's electrovalve? how does it work?
Message par jojoe31 » 17 mai 2011, 17:00
i got it §!!!!!!!!!!!!! :mrgreen:
If you disconnect this hose, your automatic chocke is getting air in the water circuit : which means, lower temperature => automatic chocke is on !
Completely normal, you don't have a problem man !
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 mai 2011, 17:46
really?
So the engine shouldn't stop when i disconnect the wire from this valve?
Message par jojoe31 » 17 mai 2011, 17:50
at all !
you're just wasting water and getting air bubbles in your engine !!! NOT GOOD ! X|
Just bleed your water circuit very well and everything will be fine.. :super:
Once, i made more then 1000km with the electric wire disconnected..the weather was fine, i didnt see any difference ! :hello:
Just dont play with the water circuit..the automatic choke is very sensible with that !
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 mai 2011, 18:12
jojoe31 a écrit :at all !
Thank you very much! I think I understand now its purpose, so it is some kind of pressure adjuster within the carb ok.
It seems you know a lot about this carb :) could you also tell me what number 7 4 and 5 are in this picture?
Number 6 is this solenoid valve we talked about and 11 the anti-flood valve?
Uploaded with ImageShack.us
Message par jojoe31 » 17 mai 2011, 18:35
i didnt understand your question : you want to know what does the number 7 , 4 and 5 do in the carburator ?
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 mai 2011, 19:01
yes, what are they called or what do they, because i need to know if i buy them or not? Has no 7 any link with no 11 ?
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 18 mai 2011, 12:06
I found a great book on these carbs
http://www.scribd.com/doc/46823952/solex-z1" onclick="window.open(this.href);return false;
Does anyone know what it's called or where can I find the rest?
Message par alargeau » 18 mai 2011, 12:55
Without any doubt, it's a book from Haynes.
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 18 mai 2011, 17:04
yes, I think I found it
http://www.haynes.co.uk/webapp/wcs/stor ... &langId=-1" onclick="window.open(this.href);return false;
The solex Z1 is mine right? Because I am thinking of buying it from ebay, what do you think?
Or the older one is better from 1997?
http://www.amazon.co.uk/Automotive-Carb ... 1859602886" onclick="window.open(this.href);return false;
the first has 400 pages and the second 480
Message par alargeau » 18 mai 2011, 17:55
Do you understand Russian? :mrgreen:
Message par jojoe31 » 18 mai 2011, 18:10
Hello
Sorry but I couldn't answer earlier to your questions.
Your carb is the 34 34 z1: automatic choke for 1.6 and 1.9.
But watch out,its not the same reference.the 1.9 has the same look but inside,complete other story.I will give u the difference when I'll be on my pc.
Check my topic,I switched my auto choke to a manual one.I gained at least 1L/100km..
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 18 mai 2011, 19:21
russian? both are in english
I just want to know which to buy. The new one:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT" onclick="window.open(this.href);return false;
or the old one:
I don't want to change it to a manual, I will try to fix this one after my exams. Its problem is with the anti-flood valve (or membrane) and some settings within the choke, it should work fine afterwards. If I can't do it I will buy another carb from thefunkyboy :)
Anyways I will need a book, and these seem the best.
Message par jojoe31 » 19 mai 2011, 01:07
i dont know which one you should buy...maybe the price difference is because you got a new and old book ?
Buy the cheapest first :mrgreen:
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 19 mai 2011, 01:51
i went with the new one from ebay
What are the differences you were talking about?
Message par jojoe31 » 20 mai 2011, 10:29
amilo123 a écrit :i went with the new one from ebay
Sorry , i can't tell you the difference... :hello:
