carburretor benzin leak
If your hands are dirty, that's the forum you should post in.
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 16 août 2011, 21:27
I am having a big problem with my solex 34/34 Z1 carb... Benzin is literally dripping from one screw (pictures below).
The smell of benzin around the car is huge.
I will let the pictures tell the story...
Here are the 3 screws in red. You can see the benzin dripping out. This is with the engine running at idle. The blue circle is the accelerator pump. This is from the battery's side
This is from the front, the same screw. Idle also
Close up at idle.
This is the side from the alternator. Idle. You can see that benzin is also on the thing that it is connected to the first accelerator valve.
This is with the engine off for a couple of minutes, and intentionally flooded by me.
Here is the back. You can see the first accelerator valve's things, filled with benzin....
I think I am having a problem with this selenoid, in red. Also with the gasket in blue, even though that is 1 year old only...
Please any advice would be helpful, I think it is a dangerous problem, and the mechanics here don't repair carbs any more, and the few how do aren't really that good...
Re: carburretor benzin leak
Message par thefunkyboy » 16 août 2011, 21:45
Oh my god! Totally broken your carburator, be carefull when hot, it can burn :S
Message par alargeau » 16 août 2011, 23:11
8|
Change it!!!
sedio309
Modèle(s) 309 : GT
Message par sedio309 » 17 août 2011, 01:47
those fuking Solex...I had one for 6 years and I suffered too much..
Message par thefunkyboy » 17 août 2011, 07:47
The same, I got one, I stopped suffering by buying a new one ... expensive!!
But don't worry, Razvan has normally a solution to this carburator ;)
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 août 2011, 10:05
I will change it ASAP
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 août 2011, 10:20
sedio309 a écrit :those fuking Solex...I had one for 6 years and I suffered too much..
what did you do with it? did you changed it?
sedio309
Modèle(s) 309 : GT
Message par sedio309 » 17 août 2011, 18:08
I change ALL che joints, ciclers and that stuff..I made a semi-complet refrubrished...
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 août 2011, 18:43
sedio309 a écrit :I change ALL che joints, ciclers and that stuff..I made a semi-complet refrubrished...
I did that also, last year, but this seams to be beyond repair.
sedio309
Modèle(s) 309 : GT
Message par sedio309 » 17 août 2011, 21:35
this Solex carburetor curve on which rests against the manifold and suck air. maybe you can "brush" basis, but be careful because there are tubes that pass by ...
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 17 août 2011, 22:01
sedio309 a écrit :this Solex carburetor curve on which rests against the manifold and suck air. maybe you can "brush" basis, but be careful because there are tubes that pass by ...
It would make no difference, the problem isn't just there
Anyway, I already found a replacement. The carb is identical but it comes from a 1.6. My question is what parts are different from a 1.6 and a 1.9, apart from the jiglores?
Message par SRDTURBO » 17 août 2011, 22:25
Probably the emulsion tubes:
Message par thefunkyboy » 17 août 2011, 23:04
Razvan, the carburator comes from a 1,9 but has been adapted to 1,6. Normally, there is all the needed parts to go back to the genuine configuration
