Restoring the power of a 1986 110bhp XU92C engine
Re: Restoring the power of a 1986 110bhp XU92C engine
You mean this:
That's a wishbone:
That's a wishbone:
- missa91
- Modèle(s) 309 : GR
What you mention is called a drive shaft. It's probably the wheel side. I don't know on your particular transmission model if you can replace only the side by the wheel or the whole drive shaft, as is the case with mine. It's not that alarming, but if you let it persist, it will damage the wheel bearing or the suspension. Also, after a long time unattended, it can break and make a lot of mess, not to mention the car is then immobile.
It's great to hear you fixed your carb without having to buy another one!
309 GTI 8V 5-Door Phase 2
- amilo123
- Membre SR
- Modèle(s) 309 : GT
This is my second one. I bought it almost 2 years ago, but it was never tuned properly.
Yes that is the part. I thought that a drive shaft was somenthing else.
I am not sure if I can replace it piece by piece, but both parts are worn, so I will buy a new one.
- missa91
In my experience quality drive shafts are expensive. I could choose here by three quality grades, first there was this Italian made for 120eur, the second one was a german refurbished one for 170eur, and a french original for 260eur. Note that this is the left drive shaft, which is some 30% cheaper than the right.
Are you still loyal to Peugeot or is the daily driver some other make?
You better buy GTI drive shafts, normally all the new ones are strong GTI models but be carefull with refurbished parts.
- amilo123
- Membre SR
missa91 a écrit :In my experience quality drive shafts are expensive. I could choose here by three quality grades, first there was this Italian made for 120eur, the second one was a german refurbished one for 170eur, and a french original for 260eur. Note that this is the left drive shaft, which is some 30% cheaper than the right.
No it is not my daily driver anymore but I still maintain it.
I want to change the drive shaft this week. And it seems that there are 2 models available for the left side.
One is 575mm long, they have it in stock, GR is the brand, 80euro, new. I also found it for a mere 45 euro, but I am not sure if it is available any more, new also.
And the other is over 600mm long, 110 euro, and they can't bring it anymore.
What is the correct one for my car?
- missa91
575mm if it's the model that has 25 teeth on the wheel side and 24 on the transmission side
- amilo123
- Membre SR
missa91 a écrit :575mm if it's the model that has 25 teeth on the wheel side and 24 on the transmission side
What about the transmission oil? What grade should I use?
- missa91
It depends on the climate. I use some Total, I think it's SAE80-90. But I'm not sure about your transmission.
75W80 for gearbox oil. It's what I put on my GT wich has the same motor than you
