309GT transmission oil type
- amilo123
- Modèle(s) 309 : GT
Does anyone know what type of oil my gearbox needs?
Re: 309GT transmission oil type
You need 70w80
edit: 75w80! Sorry for the mistake
- amilo123
Last year I put 75w90, Total full-syntethic GL4 / GL5.thefunkyboy a écrit :You need 70w80
Should I change it again??
- amilo123
Are you guys sure? I have to change t now and I want to be sure.
I can't find 70w80, but if this is the one I need I will search more for it.
The 75w90 from last year was doing fine even when really cold?
If yes you can keep using this grade, the gearbox is not a clock and in fact the BE1 was first fitted with engine oil.
- amilo123
It was OK, not that bad, it was kinda hard to get into first when cold, but it didn't bother me.SRDTURBO a écrit :The 75w90 from last year was doing fine even when really cold?
Normally, it's 10w40 in the gearbox, same oil as the engine.
But, for my GT, I put 75w80 for the gearbox with no problem.
- amilo123
I also knew that this gearbox uses 10W40, that is why I put 75W90, because I found this on wikipedia:
"many modern gearboxes use a 75W90 gear oil, which is actually of equivalent viscosity to a 10W40 motor oil."
Also I heard that this gearbox uses GL-5, so I will buy Liqui Moly 75W90 GL-5. I used Liqui Moly in the engine as well for a year now, and I am pleased with it.
For 309, it's 75W80 for gearbox MA and BE3, not 75W90.
My mechanic put 75W80 for GT.
