XU92C oil quantity
Posté : 05 sept. 2011, 20:09
par amilo123
How much oil should I put on an oil change. I always put 4l, but now I see that in the book it says 4.5l and in heynes 5l.
BTW: I will buy this mobil 1 full synthetic. http://www.mobiloil.com/USA-English/Mot ... 0W-40.aspx" onclick="window.open(this.href);return false;
Re: XU92C oil quantity
Posté : 05 sept. 2011, 20:16
It is between 4.5 and 5L. I use to start the engine after changing oil. It permits to fill in the oil filter. Then, you can adjust the oil volume.
Posté : 05 sept. 2011, 20:17
par beni
I think it 4.5litres .... anyway it is not higher than the edge !
if you put all the time 4 liters, maybe you do not drain enough?
Posté : 05 sept. 2011, 21:00
par amilo123
maybe...
Posté : 05 sept. 2011, 22:37
I'have a XU92C engine, and in the book it says that you put 4,5L whithout changing the filter, and 5L if you change it.
Posté : 08 sept. 2011, 17:02
A good way to drain more is to drain when the engine is totally cold, so the oil will be down. Then, you should be able to drain almost 5 liters with the filter.
