Peugeot 309 1.9 XS
- Al_Bundy
- Modèle(s) 309 : 309 xld
Re: Peugeot 309 1.9 XS
no,entire inside was moved out,but maybe somwhere is written number,ill try to fiind it
score 4 touchdowns in just 1 game!
- Al_Bundy
bad news,i dont know the mileage,but,if i remember well,it didnt had too much on it.
Less than 100k?
- Al_Bundy
i think less than 180 000km,and that is small number for 309
- Al_Bundy
Have a problem,maybe you can help me with this:
I was reconnecting the wires back and some i manage to figure it out where they go,some i didnt.
Its a bad quality pics but maybe you can see that there are some cutted wires,well,i wanted to reconnect back,and there are 3 purple.
If they are all the same color,do that meens that i can connect them like i want?
Im connecting yellow with yellow,blue with blue etc,but here are some wires with same color so i was wondering if i can mix them,becose i dont know which one goes where so maybe it doesnt matter if they are same color?
Thanks
Thanks
You should be able to see a number on each wire. Just have a look at the wires and you'll see numbers on them. Then, attach corresponding numbers to each other.
- Al_Bundy
I found numbers on some wires but is ok,i manage to reconnect most of wires back,just was wondering if i can connect wires with the same colors.
Thanks alargeau for your help.
Numbers are more important than colors. Because as you noticed, some wires have the same colour. Sometimes the number is quite far from the end of the wire but it's always there. You just need to find it.
It'll be hard to understand if he doesn't understand French...SRDTURBO a écrit :http://issuu.com/lamicale309/docs/schem ... riques_309
- Al_Bundy
ok,ill try with translator to tunderstand french,thanks for your help guys
- Al_Bundy
I have found the marks on wires,unfortunatly,they are only at the end of wires so its a bit dificult to determine which one is which but im getting there slowly.
I must take disconnect most of wirings so i can see which one is which,ill do that today.
thanks again for help.
XU9J1 is page 074 (injection only). Then you have colours and wires numbers. Regarding colours:
- ba = white
- or = orange
- ve = green
- be = blue
- vi = purple
- vj = green-yellow
- mr = brown
- jn = yellow
- rg = red
- gr = grey
- na = natural (I don't know what they mean exactly)
- bg = beige
- nr = noir
- rs = pink
Then you can also go to page 066, which deals with the fuel pump. If you go to page 001, that's the ignition coil wiring loom.
Then, everything is here (00X is page number):
--- LEFT COLUMN 1 ---
- starter: ignition coil XU_JA: 002
- starter: ignition coil TU, XU52C & XU92C: 003
- starter:ignition coil XU_J1: 001
- lighter and ashtray lamp: 005
- catalytic system "C" TU3: 008
- catalytic system diesel E.G.R: 009
- ABS system: 097
- automatic gearbox, starter security XU52C & XU9J1 & reverse: 083
- automatic gearbox, XU5M_Z & reverse mode: 084
- automatic gearbox, XU9JAZ & reverse mode: 085
- driving school: 096
- radio (electricity): 006
- radio (electricity & speakers): 007
- horn (1): 010
- horn (with compressor): 011
- fuse box (equipments protected by the fuse box): 100
- fuse box (connectors, relays and fuses): 099
- fuse box general schema: 098
- lights on beeper (if car is equipped): 016
- indicators: 034
--- RIGHT COLUMN 1 ---
- ventilation (interior): 049
- rev counter: 048
- remote central locking: 059
- central locking ()without remote & 3 door models): 058
- connectors under dashboard: 106
- connectors on fuse box: 105
- connectors on cloks: 104
- connectors & splices (layout): 101
- connectors & splices (lexicon):102
- clocks & ventilation fascia lighting: 028
- number plate & tailgate lighting: 029
- glove-box lighting: 030
- splices on dashboard wiring loom: 108
- rear window wiper & pump: 012
- front window wiper & pump with delay: 014
- front window wiper & pump without delay: 013
- rear fog light: 020
- fog lights (front & rear) for models with daytime running lights: 023
- fog lights (front & rear) LHD & RHD without spot lights: 021
--- LEFT COLUMN 2 ---
- fog lights (front & rear) LHD & RHD with spot lights: 022
- low beam : 017
- parking lights: 015
- reverse lights: 024
- high beam: 018
- daytime running lights (all models): 025
- spot lights: 026
- spot lights with daytime running lights: 027
- brake lights: 019
- gendarmerie (police): 095
- Injection XU5JA & XU9JA: 075
- Injection XU5M 3Z: 079
- Injection XU9J1: 074
- Injection XU9J4: 081
- Injection XU9JAZ: 080
- Injection TU_M: 076
- Injection XU5M 2Z: 078
- Injection XU9M: 077
- fuel gauge: 039
- front headlight washer jets: 060
--- RIGHT COLUMN 2 ---
- front headlight washer jets: 061
- window regulator: 062
- rear window & exterior view mirrors defrosting: 063
- analog clock: 046
- digital clock: 047
- engine cooling fan (1 fan two 2 speeds): 051
- engine cooling fan (1 speed): 050
- engine cooling fan (2 fans 2 speeds): 054
- engine cooling fan XUD7T with A/C (2 fans 2 speeds): 056
- engine cooling fan DIESEL with A/C (2 fans 2 speeds): 055
- engine cooling fan with A/C (2 fans 2 speeds): 057
- engine cooling fan delay (1 fan two 2 speeds): 052
- engine cooling fan delay with A/C (2 fan two 2 speeds): 053
- wires lexicon: 109
- rear roof courtesy light & boot light & commercial vehicle: 033
- front roof courtesy light & map reader & doors switch: 032
- front roof courtesy light: 031
- police unmarked vehicle: 093
- police marked vehicle: 094
- fuel pump (immersed): 065
--- LEFT COLUMN 3 ---
- fuel pump: injection & tach relay XU9J1: 066
- fuel pump: injection & tach relay XU5JA & XU9JA: 067
- fuel pump: injection & relay TU_M: 069
- fuel pump: injection & relay XU5M 2Z: 070
- fuel pump: injection & relay XU5M 3Z: 071
- fuel pump: injection & relay XU9J4: 073
- fuel pump: injection & relay XU9JAZ: 072
- fuel pump: injection & relay XU9M: 068
- clocks: oil & coolant temperature + oil pressure indicator: 036
- clocks: oil & coolant temperature + oil pressure indicator XU_M: 037
- clocks: oil & coolant temperature + pressure indicators XU_JA & XU9J1: 038
- A/C ventilation: 091
- heated front seats: 064
- hazard light: 035
- RHD models with specific parking lights: 092
- DIESEL ONLY - coolant temperature sensor: 090
- DIESEL ONLY - glow plug & indicator light: 088
- DIESEL ONLY - water-in-fuel detector & indicator light: 087
- DIESEL ONLY - fuel shut-off solenoid: 086
- DIESEL ONLY - additional heater: 089
--- RIGHT COLUMN 3 ---
- choke indicator light: 040
- diagnostic & catalytic overheating indicator light: 082
- hand brake & fluid level indicator light: 045
- coolant level indicator (diesel & gasoline injection): 044
- coolant level indicator (gasoline & single-point injection): 043
- brake pads indicator light: 041
- warning & oil pressure & coolant temperature indicator light: 042
Oh my god, I spent two hours on this!!!
- ba = white
- or = orange
- ve = green
- be = blue
- vi = purple
- vj = green-yellow
- mr = brown
- jn = yellow
- rg = red
- gr = grey
- bg = beige
- nr = noir
- rs = pink
- ABS system: 097
- horn (1): 010
- indicators: 034
- rev counter: 048
- low beam : 017
- high beam: 018
- spot lights: 026
- brake lights: 019
- fuel gauge: 039
- analog clock: 046
- hazard light: 035
- Al_Bundy
Thank you very much,i apreciate your work and it is very helpfull.
I owe you a big favor.
When you come in croatia,you got a free space to crash
You know what we say: "don't say it twice".Al_Bundy a écrit :Thank you very much,i apreciate your work and it is very helpfull.
