We wondered what name we could give to this forum and then we stopped thinking.
missa91
Modèle(s) 309 : GR
Message par missa91 » 16 juin 2011, 03:55
With the manifold you need to be persistent. If it wont come of, then be persuasive, take a hammer and persuade it. :D
I once used a crow bar. That helped a lot. Use a LOT of WD40 and hammer on the screws, but don't damage them, go easy, from side to side. Then again WD40. If not this way, try loosening the screws using a air impact wrench, I think you know what I mean, Compressed air driven tool for tightening wheel bolts, but it has to have the impact function.
309 GTI 8V 5-Door Phase 2
Message par thefunkyboy » 16 juin 2011, 07:19
To add an idea: use a very good key, like chrome vanadium KS Tools, Facom or Norauto (I don't know if you have this brand in Romania).
First time I did this operation, i used a standard one and it was very hard.
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 16 juin 2011, 15:11
I am more worried about the squeaking sound...
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 17 juin 2011, 17:47
The smell is somewhat gone, but still very bad. I went to someone else, the one who gave me the manifold, and he will change it next week.
The clutch is still squeaking, the mechanic says it should go away after awhile. I barely drove the car since I changed the clutch, so he might be right...
Message par thefunkyboy » 17 juin 2011, 18:28
One day, I put a product to seal off an exhaust leak, a part goes into the exhaust system and then , it smelled for some kilometers xD
Let's wait and see for your clutch. controle and check if the sound increases ;)
missa91
Modèle(s) 309 : GR
Message par missa91 » 18 juin 2011, 19:14
What about the advance on the ignition? How much did you set it to? I need to check my ignition once again, because I've done everything to reduce consumption, but it has no effect. I followed the 1.5-2.5K rpm rule and the consumption is the same as when I drive it at 3.5K (120kph 5th gear) about 11l/100km LPG.
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 18 juin 2011, 22:35
missa91 a écrit :What about the advance on the ignition? How much did you set it to? I need to check my ignition once again, because I've done everything to reduce consumption, but it has no effect. I followed the 1.5-2.5K rpm rule and the consumption is the same as when I drive it at 3.5K (120kph 5th gear) about 11l/100km LPG.
I set it to 10, but you gave the 1294cc G1 engine right? You should set it to 8. See below:
[IMG=http://img855.imageshack.us/img855/3373/unled3dg.jpg][/IMG]
Uploaded with ImageShack.us
missa91
Modèle(s) 309 : GR
Message par missa91 » 19 juin 2011, 14:08
Thanks for the picture. It's great that you have such a handbook. What book is this? How can I get it?
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 19 juin 2011, 21:21
missa91 a écrit :Thanks for the picture. It's great that you have such a handbook. What book is this? How can I get it?
my dad had it since he got the car. I will scan it and post it here.
And if someone has the english version that would be great.
Message par alargeau » 20 juin 2011, 07:37
I have several versions of the English one. I'll try to scan them too.
missa91
Modèle(s) 309 : GR
Message par missa91 » 21 juin 2011, 02:44
Just came of the road. I need to go out again tomorrow. Is there any news on the handbooks? If I can help in any way, just say the word!
Message par alargeau » 21 juin 2011, 09:03
I had a look at the english versions and there's no such indication as found in the Swiss one. There's only general data.
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 25 juin 2011, 02:32
I did almost 500km with this new clutch (not just city), the squeaking is still there. It's the same, not louder nor quieter.
It is not only at idle, but always when the peddle is not pressed.
Message par thefunkyboy » 25 juin 2011, 09:32
One day, a guy told me that it is possible to check the tightening of the shafts.
One is accessible normally by removing the left part of the gearbox. But I have some doubt if it works on the BE1, or only on the BE3
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 28 juin 2011, 23:46
Anyone know if the exhaust manifold is identical in diameter between mine and one from a 1.6 309?
Because that is the one I bought. The seller said it is identical, but I want to be sure.
