You should find another engine, it is easier
It won't repair the rings i think.
- amilo123
- Modèle(s) 309 : GT
lol another engine for only one cylinder?thefunkyboy a écrit :It won't repair the rings i think.
You can't change only one piston rings kit, you must change for all of your pistons. It is very expensive
- missa91
- Modèle(s) 309 : GR
In Serbia it costs about 10-12eur per cylinder, the piston rings that is. The head gasket is about 30eur. The machining of the cylinder head is about 15eur. Other gaskets come to something like 40eur (with valve seals). And the work should be at about 70eur. because being a mechanic here in Serbia is a bit under appreciated.
309 GTI 8V 5-Door Phase 2
True for a MK2, in a MK1 the XU92C is not the samethefunkyboy a écrit :just change the cylinder head. It is the same one XU52C, XU92C and GTI (excepted the cam shaft)
Yes you are true Baptiste
- amilo123
so this is the reason why the oil pressure drops form over 4 to 2 after 4000rpm?
Maybe but you know, the oil sensor isn't so reliable xD
- amilo123
same here I think, 200-300euro. I will let it be for now...missa91 a écrit :In Serbia it costs about 10-12eur per cylinder, the piston rings that is. The head gasket is about 30eur. The machining of the cylinder head is about 15eur. Other gaskets come to something like 40eur (with valve seals). And the work should be at about 70eur. because being a mechanic here in Serbia is a bit under appreciated.
- amilo123
But now I have to do something with the oil overheating, because almost always it reaches the second line after 90.
Are you guys sure it is only the ignition timing?
- missa91
And the oil overheating might be causing some of the engine trouble...
- amilo123
Unfortunately I can't find a mechanic with a timing light lol, but I found a timing light on the net, but it's 37eur... not sure if it's worth it.
- missa91
Look at it this way: When you buy it, everybody will come to you to test their ignition
And you can make the money in no time LOL
- amilo123
true:)missa91 a écrit :Look at it this way: When you buy it, everybody will come to you to test their ignitionAnd you can make the money in no time LOL
Totally right!! Plus when you will have all sorts of tools, you will be able to open a garage!missa91 a écrit :Look at it this way: When you buy it, everybody will come to you to test their ignitionAnd you can make the money in no time LOL
