Restoring the power of a 1986 110bhp XU92C engine
We wondered what name we could give to this forum and then we stopped thinking.
Re: Restoring the power of a 1986 110bhp XU92C engine
Message par thefunkyboy » 25 mai 2011, 20:16
It won't repair the rings i think.
You should find another engine, it is easier ;)
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 25 mai 2011, 20:30
thefunkyboy a écrit :It won't repair the rings i think.
lol another engine for only one cylinder?
Message par thefunkyboy » 25 mai 2011, 20:38
You can't change only one piston rings kit, you must change for all of your pistons. It is very expensive
missa91
Modèle(s) 309 : GR
Message par missa91 » 25 mai 2011, 21:12
In Serbia it costs about 10-12eur per cylinder, the piston rings that is. The head gasket is about 30eur. The machining of the cylinder head is about 15eur. Other gaskets come to something like 40eur (with valve seals). And the work should be at about 70eur. because being a mechanic here in Serbia is a bit under appreciated.
309 GTI 8V 5-Door Phase 2
Message par SRDTURBO » 25 mai 2011, 21:17
thefunkyboy a écrit :just change the cylinder head. It is the same one XU52C, XU92C and GTI (excepted the cam shaft)
True for a MK2, in a MK1 the XU92C is not the same :nonon:
Message par thefunkyboy » 25 mai 2011, 21:25
Yes you are true Baptiste :rouge: :aille:
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 25 mai 2011, 23:32
so this is the reason why the oil pressure drops form over 4 to 2 after 4000rpm?
Message par thefunkyboy » 25 mai 2011, 23:39
Maybe but you know, the oil sensor isn't so reliable xD
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 25 mai 2011, 23:48
missa91 a écrit :In Serbia it costs about 10-12eur per cylinder, the piston rings that is. The head gasket is about 30eur. The machining of the cylinder head is about 15eur. Other gaskets come to something like 40eur (with valve seals). And the work should be at about 70eur. because being a mechanic here in Serbia is a bit under appreciated.
same here I think, 200-300euro. I will let it be for now...
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 26 mai 2011, 10:08
But now I have to do something with the oil overheating, because almost always it reaches the second line after 90.
Are you guys sure it is only the ignition timing?
missa91
Modèle(s) 309 : GR
Message par missa91 » 26 mai 2011, 16:53
And the oil overheating might be causing some of the engine trouble...
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 26 mai 2011, 22:03
Unfortunately I can't find a mechanic with a timing light lol, but I found a timing light on the net, but it's 37eur... not sure if it's worth it.
missa91
Modèle(s) 309 : GR
Message par missa91 » 27 mai 2011, 01:18
Look at it this way: When you buy it, everybody will come to you to test their ignition :D And you can make the money in no time LOL
amilo123
Membre SR
Membre SR
Modèle(s) 309 : GT
Message par amilo123 » 27 mai 2011, 09:33
missa91 a écrit :Look at it this way: When you buy it, everybody will come to you to test their ignition :D And you can make the money in no time LOL
true:)
Message par alargeau » 27 mai 2011, 09:43
Totally right!! Plus when you will have all sorts of tools, you will be able to open a garage! :hehe:
