The smell of benzin around the car is huge.
I will let the pictures tell the story...
Here are the 3 screws in red. You can see the benzin dripping out. This is with the engine running at idle. The blue circle is the accelerator pump. This is from the battery's side
![Image](http://img9.imageshack.us/img9/6427/imag0270o.th.jpg)
This is from the front, the same screw. Idle also
![Image](http://img710.imageshack.us/img710/4098/imag0271t.th.jpg)
Close up at idle.
![Image](http://img51.imageshack.us/img51/6341/imag0273c.th.jpg)
This is the side from the alternator. Idle. You can see that benzin is also on the thing that it is connected to the first accelerator valve.
![Image](http://img822.imageshack.us/img822/1904/imag0275z.th.jpg)
This is with the engine off for a couple of minutes, and intentionally flooded by me.
![Image](http://img831.imageshack.us/img831/7688/imag0276j.th.jpg)
Here is the back. You can see the first accelerator valve's things, filled with benzin....
![Image](http://img38.imageshack.us/img38/1861/imag0277hc.th.jpg)
I think I am having a problem with this selenoid, in red. Also with the gasket in blue, even though that is 1 year old only...
![Image](http://img221.imageshack.us/img221/4971/imag0278t.th.jpg)
Please any advice would be helpful, I think it is a dangerous problem, and the mechanics here don't repair carbs any more, and the few how do aren't really that good...
