5w40 or 10w40 oil? Benzine excess consumption?
Re: 5w40 or 10w40 oil?
Message par thefunkyboy » 21 mars 2011, 20:06
This carburator is very bad. I had to change it by a new one last time :S
I used to consume 12L/100km in the worst case
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 21 mars 2011, 20:12
thefunkyboy a écrit :This carburator is very bad. I had to change it by a new one last time :S
It is very bad indeed. I searched for a new one but could find one. Not even a second hand one...
Message par thefunkyboy » 21 mars 2011, 20:15
You can have a new one thanks to the Amicale 309, we have some contacts :super:
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 21 mars 2011, 21:21
thefunkyboy a écrit :You can have a new one thanks to the Amicale 309, we have some contacts :super:
Interesting:)
How much is one? Does it come from France?
Message par thefunkyboy » 21 mars 2011, 22:46
Yes, it comes form France. It is a little bit expensive but worthwhile.
The price is about 350€ without delivery.
The best solution would be to order collectively with other people (french and european)
viewtopic.php?f=55&t=1100" onclick="window.open(this.href);return false;
amilo123
Modèle(s) 309 : GT
Message par amilo123 » 21 mars 2011, 23:07
thefunkyboy a écrit :Yes, it comes form France. It is a little bit expensive but worthwhile.
quite expensive...It doesn't run that bad to justify the expense, plus the gaskets are new, got them for 20 euro :langue3:
Message par thefunkyboy » 21 mars 2011, 23:18
Sometimes, it is possible to find good second hand parts on http://www.leboncoin.fr" onclick="window.open(this.href);return false;
missa91
Modèle(s) 309 : GR
Re: 5w40 or 10w40 oil? Benzine excess consumption?
Message par missa91 » 03 avr. 2011, 16:26
I used to have a bad problem with my carburetor, but i got it repaired for 35eur here in Serbia. It used to consume up tp 18l/100km in the city. Indeed I drive a little faster, but it is a 1.3! Now the consumption is around 7l/100km, but i opted for LPG and reduced my costs a lot! My mechanic did a great job and the car really uses very little gas now, like 7l/100km LPG.
Here you can find some great shape second hand carburetors for less than 40eur. My friend bought one of a car that came form Switzerland. He is completely satisfied.
309 GTI 8V 5-Door Phase 2
Message par thefunkyboy » 03 avr. 2011, 16:31
You put LPG on your Simca engine?? Do you have pics?
missa91
Modèle(s) 309 : GR
Message par missa91 » 03 avr. 2011, 16:34
yeah i put some on in my showroom, but if you want detailed ones i will take them and put them up...
Message par thefunkyboy » 03 avr. 2011, 16:58
I saw them but I am curious about seeing the assembly :)
missa91
Modèle(s) 309 : GR
Message par missa91 » 03 avr. 2011, 17:14
Well you have your vaporizer, it requires coolant to run through it, You have the tank, I fitted mine in the boot and you have a copper pipe from the boot to the vaporizer running underneath the car. On my Simca I fitted a electronic vaporizer because my ignition is electrical. You have three valves. One is the main gas valve and one is the main LPG valve. There is a selector in the cabin and once you turn the key to the running position it opens the one that is selected, either LPG or gasoline. Then for the LPG there is a second valve on the vaporizer which opens with every impulse the ignition coil sends out.
From the vaporizer there is a hose running to the carburetor and all you do is put a hole in the carburetor body to allow for a little fitting to be inserted. The carburetor is only needed to regulate the fuel/air mixture, all other settings are done on the vaporizer itself.
I will go outside and take some pics for you to see.
Message par thefunkyboy » 03 avr. 2011, 17:17
Thanks in advance for your explanations and the pics :)
Message par alargeau » 03 avr. 2011, 17:38
So did you fit it yourself?
missa91
Modèle(s) 309 : GR
Message par missa91 » 03 avr. 2011, 17:46
The pics and explanation are posted on my showroom...
