peugeot 309 xud now xud7te
Hi! I'm the prowd owner of an 1992 peugeot 309 it was an xad model now it has many parts form gti like seats, dashboard, outside ornaments etc and an xud7te intercooled engine with an bosch fuel pump 190 atm renault bosch injectors garret t2 turbocharger!
I ask for your help beacuse i can't make the fuel gauge to work because the electrical socket from tne fuel tank was riped i found another one but the wires are other colors so i can't say what is what.
- 309td.JPG (38.73 Kio) Vu 4324 fois
Re: peugeot 309 xud now xud7te
Do you speak french?
http://issuu.com/lamicale309/docs/schem ... riques_309" onclick="window.open(this.href);return false;
Search "jauge à carburant".
Merci, un peu! i will go reconect the wires to see what is going on !
Do you have the 1.8 td without te intercooler ?
- 222.JPG (46.74 Kio) Vu 4316 fois
Yes:
Almost the same engine with a special Lucas pump and a maybe a different turbocharger.
You can see the parts that change here:
http://fr.peugeot309.net/documents/cata ... -detachees" onclick="window.open(this.href);return false;
http://www.miamistu.co.uk/pug/" onclick="window.open(this.href);return false;
I have the bosch fuel pump beacuse is easyer to play with the boost and it's more reliable/ i'm preparing one from an 406 1.9 td to put on my car maybe i will trow an 11 mm head for more fuel but for now it's enouch for the garret t2 turbocharger an fmic.
I now a guy who is puting a T25 from a 2.0 TCT with the machined genuire T2 hot body, the engine will be a 2.1 TD12 with a 1.9 head.
Modifié en dernier par SRDTURBO le 03 févr. 2013, 20:32, modifié 1 fois.
why did he put a 1.9 head on an 2.1 engine isn't the 12valave better than the 8 valve?
I want to put an 2.1 head 12valve on an 1.9 engine, will it work?
The 8v head seem to be more reliable, also he can use a cheap factory "hi perf" old XUD7 camshaft and look more street legal.
2.1 head on a 1.9 engine? I think nobody have done that, put the entire 2.1 is way more easy.
