peugeot 309 xud now xud7te
Pitulaki
Modèle(s) 309 : 309 xud
Message par Pitulaki » 07 janv. 2013, 21:05
Hi! I'm the prowd owner of an 1992 peugeot 309 it was an xad model now it has many parts form gti like seats, dashboard, outside ornaments etc and an xud7te intercooled engine with an bosch fuel pump 190 atm renault bosch injectors garret t2 turbocharger!
I ask for your help beacuse i can't make the fuel gauge to work because the electrical socket from tne fuel tank was riped i found another one but the wires are other colors so i can't say what is what.
Re: peugeot 309 xud now xud7te
Message par SRDTURBO » 07 janv. 2013, 23:02
Do you speak french?
http://issuu.com/lamicale309/docs/schem ... riques_309" onclick="window.open(this.href);return false;
Search "jauge à carburant".
Pitulaki
Message par Pitulaki » 08 janv. 2013, 09:16
Merci, un peu! i will go reconect the wires to see what is going on !
Pitulaki
Message par Pitulaki » 08 janv. 2013, 09:21
Do you have the 1.8 td without te intercooler ?
Message par SRDTURBO » 08 janv. 2013, 18:08
Yes:
Almost the same engine with a special Lucas pump and a maybe a different turbocharger.
You can see the parts that change here:
http://fr.peugeot309.net/documents/cata ... -detachees" onclick="window.open(this.href);return false;
http://www.miamistu.co.uk/pug/" onclick="window.open(this.href);return false;
Pitulaki
Message par Pitulaki » 09 janv. 2013, 09:23
I have the bosch fuel pump beacuse is easyer to play with the boost and it's more reliable/ i'm preparing one from an 406 1.9 td to put on my car maybe i will trow an 11 mm head for more fuel but for now it's enouch for the garret t2 turbocharger an fmic.
Message par SRDTURBO » 09 janv. 2013, 16:03
I now a guy who is puting a T25 from a 2.0 TCT with the machined genuire T2 hot body, the engine will be a 2.1 TD12 with a 1.9 head.
Modifié en dernier par SRDTURBO le 03 févr. 2013, 20:32, modifié 1 fois.
Pitulaki
Message par Pitulaki » 03 févr. 2013, 19:49
why did he put a 1.9 head on an 2.1 engine isn't the 12valave better than the 8 valve?
I want to put an 2.1 head 12valve on an 1.9 engine, will it work?
Message par SRDTURBO » 03 févr. 2013, 20:46
The 8v head seem to be more reliable, also he can use a cheap factory "hi perf" old XUD7 camshaft and look more street legal.
2.1 head on a 1.9 engine? I think nobody have done that, put the entire 2.1 is way more easy.
