i have a problem with my 309 from 89 its a 1.3
when i have been driveing like 20 min its get really hard to change the gears
there is oil on geabox
when i try to change gear i can do it but its hard an it gives like a bad sound
but its not from the gearbox its like its comeing from under the car
when i drive lets say 100 km/t in 5th gear there is no missounds from the gearbox it runs smooth
hard to shift gears
Re: hard to shift gears
Have you tried to start in third gear?
The test is to:
1/ start the engine
2/ accelerate until a rythm of 2500 RPM
3/ put the third gear progressively while you are maintaining the rythm at 2500 RPM. If the rythm does not descrease, your clutch is about out of order.
The test is to:
1/ start the engine
