[sedio309] Sedio's 309
Re: Sedio's 309
To sweat or not to sweat... That is not the question because you'll sweat anyway.
Re: Sedio's 309
Very nice GTI upgrade! I hope you don't find any major problems with the modification
, Who's the other GTI from the bonus picture?
- sedio309
- Modèle(s) 309 : GT
Re: Sedio's 309
a real GTI16 the ONLY one in Uruguay, Argentina and Brazil.....it´s from my boss
Re: Sedio's 309
- sedio309
Re: Sedio's 309
the-rock a écrit :wow, your boss is very lucky to have it! so i guess the modification you're carrying on is a common practice over there right? I imagine the 8v GTI's were in limited number too... i didn't know there were 309 in Brazil!...
GTI only 8....now only 2 are alive..and one of them have an Mi16 inside....so aparently there's only 1 real GTI 8v compete in Uruguay..Mine it's a GT, not a GTI...in Brazil there were NO 309, and
Re: Sedio's 309
Hmmm quite rare GTI's in Uruguay.. [hard question] do you know if it is the same thing for Argentina? I'd like to import one in Colombia if I go back....
- sedio309
Re: Sedio's 309
Thera ar no 309 in argentina.....I mean one or two..no more...the-rock a écrit :Hmmm quite rare GTI's in Uruguay.. [hard question] do you know if it is the same thing for Argentina? I'd like to import one in Colombia if I go back....
- sedio309
Re: Sedio's 309
the-rock a écrit :![]()
i guess you're as lucky as your boss then!
no..I live in Uruguay...in Uruguay 309 thera are a lot....309GTI are only 2 actives..and only one GTI16
Re: Sedio's 309
I now a GTI16 with an aftermarket A/C, so one way or another it fits.sedio309 a écrit :That's the answer....aparently...the A/C compresor does not fit if you have an Mi16 engine ina 309 engine bay... :S
- sedio309
Re: Sedio's 309
your GTI16 have A/C??? original GTI compressor???SRDTURBO a écrit :I now a GTI16 with an aftermarket A/C, so one way or another it fits.sedio309 a écrit :That's the answer....aparently...the A/C compresor does not fit if you have an Mi16 engine ina 309 engine bay... :S
Re: Sedio's 309
Not mine,I don't now if it was a compressor from a 405 or a 309 (5 pistons on the 309 and 7 on the 405) ; the A/C convertion was probably make in Italy if I remember well. The radiator support was probably a regular 2 fans
Instread of the special from GTI16:
I remember well than the radiator was very close to the intake and looks like a regular GTI/diesel/GTI16 radiator (the A/c radiators are normally 10mm larger just like in a 309 with supercharged diesel engine).
- sedio309
Re: Sedio's 309
emm...I do not understand to much what you did to put the A/C, did you change the water radiator sistem??
Re: Sedio's 309
He doesn't know, it's not his car. He just assumes the radiator is the same.
- sedio309
Re: Sedio's 309
aha....well...you have work to do...jajaja....I need to know how is that this 309GTI16 has A/C...
I COMMAND YOU!!!!
I COMMAND YOU!!!!
